carb leaking
Old Mar 14, 2004 | 06:14 PM
Jonsride's Avatar
Default carb leaking
Theres a vent line coming off the carb bowl and routes back and lays on the swing arm. I'm occasionally getting gas leaking (pouring)out of it and the bike will stall then not start. It seems maybe the float might be sticking and flooding the engine. I'm I on the right track.? It only happens occasionally but usually at a inopertune time ( i.e. uphill ) . And is the remedy rebuilding the carb or is there something simplier? Thanks
Old Mar 14, 2004 | 06:27 PM
Eaglecollector's Avatar
Sounds like maybe the float needle valve is sticking and letting fuel to continue to fill the carb bowl. Possible that it is just gotten a peice of dirt / sand causing your probs. Take her apart and blow evrything with compressed air. If you don't run a fuel line filter...I would get one. Also before you put it all back together check the float level for proper level.
Old Mar 14, 2004 | 06:40 PM
Jonsride's Avatar
Thanks . I had a hunch that might be it. I'll give it a try .
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
