carbs
Old Mar 15, 2004 | 07:27 AM
rob0781's Avatar
Default carbs
will a 110 honda trike carb bolt up to a 200 trike?I know it wouldn't work i just wanna know if it would fit?
Old Mar 16, 2004 | 01:44 AM
KNOWSALOT's Avatar
The Facility
Default carbs
Wouldn't even be close and even if it did, the smaller 110 carb would barely flow enough to keep the engine at idle....if at all.
Larger is where's it at. Find you a XR200R carb.
Old Mar 16, 2004 | 02:20 AM
rob0781's Avatar
Default carbs
Well actually i got a 82 suzuki dr100 dirtbike and right now it has a carb on it off of a 200 honda trike which bolts up perfect,the only thing is if i slowly open it up it's fine but if i crack it open fast it over fuels and bogs so i was thinkin if a 110 carb would fit it'd probally work good,i looked for a used suzuki carb for the bike there not cheap,anyway would it fix my problem if i adjusted the jetting on the carb?Anyone with pic and detail on adjusting the jetting please post it i'm gonna try that before i spend some money.Rob
Old Mar 16, 2004 | 02:37 AM
KNOWSALOT's Avatar
The Facility
Default carbs
Jetting isn't going to fix it.
You could change how much fuel comes in......but not the velocity of it with the bigger bore.
Same goes with the air supply.
A better carb for you to find would be one from a '86-'87 ATC125 or '87-'88 TRX125....They use a carb as the same design as the 200 models but with a smaller bore. It will bolt on anywhere that a 200 carb will bolt up to.
The 110 and early 125 carbs are much smaller than the later ones and are of a different design regarding how it mounts up.
Old Mar 16, 2004 | 02:43 AM
rob0781's Avatar
Default carbs
Thanks for the info i'm gonna try one of the carbs you listed above see how that works..Thanks
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
