Predator cdi, and handlebars????
Old Mar 15, 2004 | 05:43 PM
fidge1's Avatar
Default Predator cdi, and handlebars????
I just picked up some renthal bars for my predator becuase i dont like how the stock bars have that huge curve to them. I was looking at the bars that are on there now and the renthals that i have and i cant figure out how to mount the gauge cluster becuase it will hit the bar pad and crossmember on the renthal bars. Is there anything you guys are doing to mount that somewhere else or do i have to buy a kit? Also who makes the best cdi, rev limiter kit for the predator. I would like to buy one this week but im not sure which company to go with--- white bros., procom, rath, hpd ??????
Old Mar 15, 2004 | 09:30 PM
stryder's Avatar
that's why when I get my handlebars I'm going with the 1 1/8 trail tech high bend and mount.
As far as CDI, I've got the procom off of Ebay for $117 total. No problems at all. The Rath and Hpd I believe are better units as far as offering adjustability, but they are way over priced. I've got great gain for a couple hundred less of the procom.
Old Mar 16, 2004 | 03:18 AM
Sniclefritz4's Avatar
yep yep, go for dem trail tech bars, my buddy has renthal bars and he rolled ONCE and messed them up, i have rolled many many times and i have yet to bend my x bars
Old Mar 16, 2004 | 04:18 PM
RuckusRacing's Avatar
On my quad I moved the choke & Ing. switch down to the upper shock mount crossmember in the frame. It already has holes stamped in it and they fit perfect. I done away with the 2 idiot lights. Trail Tech does make a 7/8 bar clamp but I don't know if it would work with a bar that has a crossbar. The thing I don't like about the trail tech setup is you can't run any type of bar pad.
Old Mar 16, 2004 | 05:07 PM
pudljumpr's Avatar
You can also drill out holes so that your key, choke, and lights go on your front cab. You could set the key off to the lower right. But then you have to remove them all when you remove the front cab, but they all come off pretty quick anyway.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
Elkaholic
Sep 6, 2015 02:44 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
