Decompression Pin in Raptor Motor ----
Old Mar 17, 2004 | 05:56 PM
RaptorOwner's Avatar
Default Decompression Pin in Raptor Motor ----
To leave or to take out??? Has anyone taken out the pin and how well does the motor still turn over with the starter? I know on the 727's that I have seen they are taken out and have to be pull started.
Old Mar 17, 2004 | 09:52 PM
wshrdskin's Avatar
I'd leave it in personaly. If you take it out, you'll probably want to weld up the hole and leave the lever in place to keep up the oil pressure.
Old Mar 17, 2004 | 09:56 PM
BigScary's Avatar
why would you want to take it out?
Old Mar 17, 2004 | 09:57 PM
BigScary's Avatar
edit:
my 11:1 Je 686 had hell turning over when we left out the decompression pin.....
Old Mar 17, 2004 | 11:12 PM
edit:
Well just in case the thing falls out and ruins the head. I dont know how it would happen but I heard of two that have done it.
I just wanted to know what the difference would be and now that you have had a problem turning over the motor then I will just keep it in.
Old Mar 17, 2004 | 11:36 PM
LOWBOWTIE's Avatar
I have done it and all I'll say is you better stock up on starters and batterys.[img]i/expressions/face-icon-small-shocked.gif[/img] Mine was 12:1 @ the time.
Old Mar 18, 2004 | 06:04 AM
Yamaha660R's Avatar
Sounds like you should definetly leave it in.
Old Mar 18, 2004 | 07:33 AM
ClutchOlds's Avatar
Mine started fine, pull starting. The pin can come out if it breaks into two pieces. How and why it broke in half is beyond me. Probably my bad luck. I put it in my hotcam exactly the way it was supposed to be. I found the old pin and well it was pretty messed up, so it was hard to tell what happened. But if your going to use a starter I would use a decomp pin. IMO
Old Mar 18, 2004 | 08:31 AM
garyc660R's Avatar
I will tell you why it messed up. Hot Cams unacceptable decompression pin hole tolerences. I have owned 2 Hot Cams and had too modify BOTH decompression pin holes for proper operation of the decompression mechanism. Your pin stuck in the out position and got lunched.
Old Mar 18, 2004 | 10:32 AM
That modification should have been in the instructions if you ask me.
