help with a 200s
Old Mar 18, 2004 | 04:38 PM
loveotride123456789's Avatar
Default help with a 200s
doses anyone kow why my friends 200s runs real loud and in its hight gear you can almsot run as fast as it and the exst is fine
thanks for any help
Old Mar 18, 2004 | 05:15 PM
drummerguy84's Avatar
WHAT DID HE DO TO IT?
Old Mar 18, 2004 | 05:44 PM
oniy a cobra exhust that was made for it .
Old Mar 18, 2004 | 06:33 PM
my exaust is pretty loud, I gotta re pack the muffler, its gettin to the point whare the windows shake...lol
Old Mar 19, 2004 | 01:38 AM
KNOWSALOT's Avatar
The Facility
lovetoride,
A loud exhaust and a slow moving trike that you walk past in high gear isn't an exhaust problem. If you said the exhaust sounded quiet and restrained....maybe, but it sounds to me like your buddies clutch has headed south.
If you can run as fast as the trike runs in high gear, a clutch adjustment isn't going to fix it.
Pull the right side cover from the engine and check the friction plates of the manual clutch assembly. If that's OK....go to your Honda dealer and buy a spanner nut wrench [$15.00] and pull the centrifugal clutch assembly and inspect it. The shoes should have grooves and the hub should not. Both are likely shot if you guys have been running this for a while in this condition.
Old Mar 21, 2004 | 09:26 PM
on his 200 it dose not have a manul cluch if id dose it was never on there sicne he had it .
Old Mar 22, 2004 | 10:17 AM
KNOWSALOT's Avatar
The Facility
It does have a manual clutch. I am not referring that it has a "manual operated" clutch.
It has a clutch just like a 200X for example, only that it is engaged by the foot shifter rather than a lever on the handlebars. It's automatically operated, but the part itself is still known as a manual clutch. Most guys refer to them on auto quads as being a "clutch pack"........so maybe that will help you figure out what I am talking about.
lonerider856
Oct 13, 2023 03:45 PM
dannytas
Sep 26, 2017 06:31 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:54 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
