Polaris 350 What's the compression suppose to be?
Old Mar 18, 2004 | 05:14 PM
ESDAMan's Avatar
Default Polaris 350 What's the compression suppose to be?
I'm getting right around 50 PSI. Is that enough? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 18, 2004 | 05:18 PM
CED's Avatar
CED
You should have over 100 for sure.Probably somewhere around 120.
Old Mar 18, 2004 | 09:05 PM
polarisman3's Avatar
yeah around 120.....but be sure to take off the air filter(and kill the engine with the kill switch before cranking) and hold the throttle wide open with the spark plug out and the compression gauge screwed tightly into the spark plug hole....then make sure you battery cranks the engine fast and keep cranking till the gauge quits going up.....
Old Mar 18, 2004 | 09:10 PM
Farmr123's Avatar
100 as a minimum, and a 'healthy' engine will have 110-120.
Old Mar 19, 2004 | 08:32 AM
ESDAMan's Avatar
I'm betting that's my problem then. I didn't have the airfilter off, so I'll try that this afternoon. I'll do some searching for some part costs today too. I'm guessing new piston, rings.....
Old Mar 19, 2004 | 09:31 AM
quadwrench's Avatar
While you have the air filter out - check the round air box throat where the rubber boot to the carb attaches - a lot of times on this style air box, the throat cracks at the bottom of the juction of the throat and airbox, letting the nasties in that eat the rings.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
