185S sprocket conversion
Old Mar 18, 2004 | 05:52 PM
69Bosshoss's Avatar
Default 185S sprocket conversion
I have an '83 185S with a bent axle and good sprocket and a '82 185S with a good axle and uses the older rubber damper type sprocket application. I thought is was going to be easy to press the hub off of the '83 and onto the '82 axle but find that the machine shop says it they can't pressed it off. They mushroomed the bad axle threads trying. My only other option would be to put the '82 axle in with the rubber dampers but the sprocket is bad and so are the dampers. What do I do?
Can the '83 spocket hub be pressed off, maybe it is tapered and was being pressed the wrong direction? Are the rubber dampers and sprocket still available? (I've seen the sprocket on eBay) Is a sprocket made that will bolt directly to the damper type sprocket hub even though the diameters are different between the 2 years?
Thanks, Bob. bobpotts@nctimes.net
Old Mar 19, 2004 | 01:27 AM
KNOWSALOT's Avatar
The Facility
Bob,
I posted a response to your question in the other thread labeled 185 axle bearings........sorry but I ran across it before seeing this one.
Dennis Kirk carries the sprocket you want in the SunStar brand.
Old Mar 19, 2004 | 06:24 PM
69Bosshoss's Avatar
Knowsalot:
Thanks, poking around and reading between the lines on ebay and here, I gathered that such a hybrid sprocket does exist. I will check it out.
Thanks for your help,
Bob
buddieboy
Dec 9, 2016 05:50 PM
shimanok2
Jan 29, 2016 07:37 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
superdizzyboi
ATC 3-Wheelers
Aug 30, 2015 07:22 PM
