400EX Kill Switch
Old Jul 14, 2000 | 12:26 AM
Skunky's Avatar
Which color is the positive coil wire on the 400EX?? It is not the same as the 300...
Old Jul 14, 2000 | 03:46 AM
NVR2L8's Avatar
It's black with a yellow stripe. When I installed a Pro Design kill switch on my 400EX, I tapped into the positive coil wire a few inches from the coil itself, and grounded the other wire to one of the l-shaped fender bracket mounts using a ring connector...grounding one end is how the directions said to install it. I suppose you could also wire the switch in-line with the positive coil wire...i.e., cut the black/yellow wire in two and connect the wires from the kill switch to the cut ends of the positive wire--the main idea being to interrupt the signal from the CDI to the coil when the clip is pulled out. BTW, the black/yellow wire can also be found coming out of the CDI (the schematic in the manual calls it the Ignition Control Module)...it's easier to get to the wire there rather than the wrapped wire bundle near the coil.
Old Jul 14, 2000 | 08:28 AM
hondatrx300ex's Avatar
yea I put mine on yesterday....connect to the black and yellow wire out of the ignition coild and ground the other.........works perfect
Old Jul 14, 2000 | 11:45 AM
Skunky's Avatar
Sweett...
Old Jul 15, 2000 | 01:32 AM
hakmazter's Avatar
I used a black/white wire on mine, it is the wire coming off the red killswitch on the left handlebar, just followed it down and tapped in......
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
toonces
Sep 5, 2015 01:14 PM
hueby
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
Hatrackr
Aug 11, 2015 09:03 PM
