tether switch
Old Mar 21, 2004 | 02:08 PM
quadracer239's Avatar
Default tether switch
Does anyone know what wires(color) that you hook a tether switch to on a 03 kfx400?
Old Mar 21, 2004 | 09:27 PM
sandblaster360's Avatar
I think you can look at (www.rocky mountain atv.com) and they have them. I think the colors are red,yellow,blue,green and more.
Old Mar 22, 2004 | 06:38 PM
newbeatle's Avatar
239... if it's the same as the Prairies & the Forces... tie into the grey wire off the ignition switch...
Old Mar 22, 2004 | 06:41 PM
fidge1's Avatar
the easiest way to find out what wire it is, is by taking a clamp on voltmeter and try each wire with the kill switch on untill you find the one that has no power and then you know to splice that one.... that what i did on my 400ex
Old Mar 22, 2004 | 07:12 PM
my bad I didnt read it correctly.
Old Mar 26, 2004 | 08:49 PM
QUADZZUKI's Avatar
Here's the info you need: "It is not necessary to remove any plastic or do any major wire moving. Squatting on the right side of the bike (brake pedal side) look just behind the radiator. There you will see the coil. It's a small black cylinder. The coil is connected by 2 (two) wires. One is black and is the "pulse wire" and the other wire is black and white. The black wire connecting to the coil will be the closest to you if you are squatting on the right side of the bike and looking toward the bike. The black wire is connected to the coil with a spade connector which pulls from the coil very easily. Use a needle nose pliers to get to it. You have to unhook it so you can work with it. To get to it you have to push gently away some other wires, etc. in the general vicinity. Now, using a small saddle type wire connector Click here -> http://auffarth.com/connector.jpg you take the long wire from the Pro Design Kill Switch and using the saddle type wire connector or similar connector, connect the Pro Design "long wire" to the black pulse wire. Now, the other wire coming from your Pro Design Kill switch (the short one) goes to any available frame bolt on the bike and is your ground wire. Remember to hook the black wire with the spade connector back up to the coil after you have connected/spliced in the long Pro Design wire. That's it to the install on the KFX400 or Z400. Just for the record you are connecting to a wire going to the coil and not actually connecting to the coil. "
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
alzgarvin
Sep 11, 2015 08:53 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
toonces
Sep 5, 2015 01:14 PM
