cylinder head cover needed...please help!!!
Old Mar 21, 2004 | 10:46 PM
appraptor's Avatar
Default cylinder head cover needed...please help!!!
I am in need of a cylinder head cover for a raptor. Does anyone know where I can get one relatively fast and relatively cheap? Ebay does not have one at the moment.
Thanks in advance
Old Mar 21, 2004 | 10:50 PM
sixsixT's Avatar
If your taking about what I think your talking about it is matched with the head. you need the head too.
Old Mar 21, 2004 | 10:54 PM
appraptor's Avatar
I guess I am a little confused when you say matched. If that is the case, why can you switch out cylinders? Shouldn't everything be interchangeable? Everything is stock on my raptor.
Old Mar 21, 2004 | 11:05 PM
appraptor's Avatar
That is not the kind of new that I want to hear. Well then, I guess the next question is where I can get an assembly? Is Ronnies.com the best place to get it?
Old Mar 21, 2004 | 11:46 PM
Raptorboy4life's Avatar
I dont know what your talking about but albaaction.com has an oem parts finder and im positive you can buy it there it might be a lttle more $ but its there! Call up your dealer if you want stock!!!
Old Mar 21, 2004 | 11:56 PM
appraptor's Avatar
both albaaction.com and ronnies.com sell the head and head cover as an assembly and you can't order each separately. I'm guessing there is a reason for this. This sucks regardless. What happened is that I broke the head cover while I was disassembling it. I didn't know that there were two allen bolts beneath the intake tappet cover and broke that little piece off. I wonder if it is repairable? Does anyone know if this would be worth repairing. It shouldn't see much pressure.
Old Mar 22, 2004 | 12:07 AM
RaptorRidrTX's Avatar
The reason the head and cover are matched parts is because of the cam journals. If they did not match perfectly you would have big problems
Old Mar 22, 2004 | 12:15 AM
appraptor's Avatar
Bartlett,
Do you think that JB weld would hold it or should I get it welded. It looks as though it is cast...steel I suppose. I am correct I believe in that this piece will not see hardly any internal pressure so I'm thinking that as long as there is a good seal, everything should be fine??? Do you have any other suggestions. This is really unfortunate and it really upsets me.
Old Mar 22, 2004 | 12:21 AM
appraptor's Avatar
how does the pm thing work?
Old Mar 22, 2004 | 08:44 AM
garyc660R's Avatar
Pick on the "LOCK" in the right-hand side of the users post you would like too contact.
