rev limiter on 400ex
Old Mar 23, 2004 | 08:29 PM
Ponder's Avatar
Default rev limiter on 400ex
is the aftermarket high rev limiters worth the 100 bucs
Old Mar 23, 2004 | 08:54 PM
emac's Avatar
i wouldnt think so unless u are hitting the rev limiter often, even then, when u are hittin the limiter the engine is already done making power so you wouldnt be getting any extra power gains out of it
Old Mar 23, 2004 | 09:38 PM
Ish416's Avatar
Exactely, the only thing the rev box's do is destroy your engine faster. Totally not worth it.
Old Mar 23, 2004 | 10:06 PM
mxer250's Avatar
The xr250r rev boxes are the ones to use. They increases the revs by 800 rpm. Thats on the powroll website. It could save u alot of money.
Old Mar 23, 2004 | 11:00 PM
duneittilludie's Avatar
Ponder- An aftermarket cdi or rev limiter is worth the cost only if you have your motor modded with a cam and other parts that will allow you to build power at the higher rpm levels.A good cdi can also change the way the power comes on from bottom to top but again on a totally stock motor you could probably get more of a performance gain with air filter ,jetting and maybe a gear change rather than a cdi.
Old Mar 24, 2004 | 02:07 AM
huskerjim's Avatar
I like mine it works super, I haven't had a problem with it and I paid 59 for it!!!
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
