bad brakes
Old Mar 26, 2004 | 01:50 PM
rinkrat's Avatar
Default bad brakes
hi
just posting a question out there i have a 95 400 kodiak with front and rear drum brakes it seems every time i go though water i seem to lose alot of my braking power any ideas thanks
Old Mar 26, 2004 | 09:26 PM
roscoe69's Avatar
Default bad brakes
the trouble with drum brakes is they always leak, after a year of use the seals that keep the water out starts to wear and lets the water in along with dirt. the brakes will get the greasy feeling and the drums will do the same . if you take it apart and check it out you may be able to clean the shoes and drum also check the hold down pins, springs etc and get the whole collection of seals and seals . there are no shortcuts on drum brakes , fix the seals or dont bother taking it apart.
Old Mar 29, 2004 | 04:19 PM
rinkrat's Avatar
Default bad brakes
thanks for that info.
would you happen to
know if there is some type of converson kit so i can convert from drums to disc
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
