Something Wrong with pipe:(
Old Mar 27, 2004 | 06:45 PM
HiFlyinRaptorRyder's Avatar
Default Something Wrong with pipe:(
I just went out and started the shee and looked down at the pipes, and i could see smoke coming from the right side. I got up under it and looked and it must not be making a good seal or something because the whole engine underneath the exhaust was wet with gas. Its not enough to be dripping on the ground, but enough that the motor is wet. This doesnt make sense because that is the side with both exhaust springs, the left side only has one spring. It has the o-ring and it looks like the pipe is snug right up against the o-ring. Earlier today, I broke an exhaust clamp and the left side head pipe fell off the exhaust manifold, but I dont see how that would make the other side leak. What do you think is causing this? I am SUPPOSED to go riding tomorrow so any help is appriciated.
Old Mar 27, 2004 | 07:53 PM
Alright I got that problem fixed, but after I did I decided to mess with the jetting since I was running a little bit rich. I moved the air/fuel screw around a couple times and couldnt find a good spot, so I decided to put it back where it was before I messed with it, and it still is messed up. It wont build rpm's until I go WOT.
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
