Banshee right side cyl is smoken!! BAD!
Old Mar 28, 2004 | 08:26 PM
Chazzman's Avatar
Default Banshee right side cyl is smoken!! BAD!
Started mt banshee after clkeanign carbs wouldnt run sprayed carb cleaner in intake to start it then the left cylinder choke side started smoken real bad.. when i shut it off it kept comen out ne ideas?...
Old Mar 28, 2004 | 10:03 PM
crispy's Avatar
I'm sorry but it's almost hard to understand what you're saying, you're words are all jumbled and the meaning is not quite clear. I'll be glad to help you, but are you saying the carb is smoking or your right side exhaust pipe is smoking or is there smoke from your head or wha? It sounds simple from what I can gather, be more specific though.
Old Mar 29, 2004 | 01:01 PM
Colby's Avatar
Sheesh, this isn't even a case of poor spelling, which can be forgiven. This is simply just lazy; typo errors that were just left in, instead of taking the time to hit "backspace" to delete and correct, no periods, not even complete sentences. Why should we take the time to try and decipher your post and type a response if you won't even take the time to make it legible?
Colby
Old Mar 29, 2004 | 01:23 PM
Shav0's Avatar
If yuo kan lrean to smell, ten wke mihgt be apple to helpe u.
katchup my drift?
Old Mar 29, 2004 | 03:45 PM
Chazzman's Avatar
Srry... i posted it in a hurry.. What i ment is my banshee wouldnt start. So i took off filter and sprayed carb cleaner in the intake to start it. It ran but the left cylinder choke side, started smoken real bad.Not sure what the cuase was, And now it pops real bad after letting off the gas. I was told jets or wirring...
Old Mar 29, 2004 | 04:51 PM
Shav0's Avatar
defently check your jetting.
where exactly is the smoke coming from in the left cylinder?
Old Mar 29, 2004 | 08:17 PM
Chazzman's Avatar
I cant see it out around the cylinder or carb its roaring out of the pipe.. I did notice the slide on the choke side carb does not move at all.. How do adjust it its totaly messed. The right side moves as soon as u thumb the throttle... Ne ideas
Joe454
Nov 20, 2020 01:19 PM
Johnny Mac
60
Dec 14, 2019 06:13 PM
badgerboy1
Sep 26, 2017 06:11 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
