2001 250 TrailBlazer-Not Charging
Old Apr 1, 2004 | 12:40 PM
easyriderNy's Avatar
Default 2001 250 TrailBlazer-Not Charging
Does anyone know the charging output of a 250 Trialblazer 2stroke? And if anybody knows how to test the stator for continuty or ohm's It would be a big help I'd hate to have to get into there if I dont have to.Also does the Cdi unit do anything with charging or just ignition?
Thank You [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 2, 2004 | 12:10 AM
quadwrench's Avatar
Not sure on the '01, but to read the charging circuit coil resistance you will need to read across the yellow/red wire to the yellow wire. You should have slight resistance (0.2 - 0.4 ohms??????) - it should not read open, nor a complete closed (0.0)
Your regulator/rectifier may be the problem is stator restistance is evident
Old Apr 4, 2004 | 10:47 AM
Thanks for the info Quad Wrench. I tested the two leads you described with my ohm meter and I had continuty between them.Does that mean its shorted? And the next question would be where is the stator? Im hoping under the pull starter.And what puller am I going to need? I ordered a shop manual for this bike it should be hear this coming week.
Old Apr 5, 2004 | 12:23 AM
quadwrench's Avatar
You will have to pull the rope starter housing and the flywheel to get to the stator - the flywheel will come off with an automotive harmonic balancer puller and 3 bolts (either 6 X 1.0mm or 8 X 1.25mm - can't remember which - I know the older 250's used the 6mm)
I didn't clarify in my previous post - When you test the stator for resistance, you need to unplug the wires and test resistance in the direction towards the stator (wires coming from the stator) - hopefully you knew this, otherwise you may have a false reading.
If your stator is bad, it can be rewound for about 1/2 the price of a new one - drop Sean at www.rmstator.com an email, he's in Canada and probably faster than ordering one from Polaris for you.
Old Apr 6, 2004 | 04:46 PM
Hey Quad Wrench
Yes I did test the wire's going back to stator.I got the flywheel off .I see two different stators. see picture > is the bottom one for charging? Because I think i can buy it $35.00.
Thanks Again
Picture of Stator> Stator
Also is there any test I could do to the rectifier? Rectifier
That runs for $65.00.
Old Apr 6, 2004 | 11:00 PM
quadwrench's Avatar
To my knowledge there are no tests for the regulator/rectifier (basically if the stator tests fine and there are no battery/wiring problems, then the last place would theoretically be the regulator/rectifier)
The lighting stator is the big 3 pole part - 01 TB Magneto #5 on this diagram - the smaller one (#4) is the exciting coil - or ignition system power.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
