New exhaust...do I need to rejet the rancher??
From what I understand you will need to rejet and I think you would also benefit from a new air filter(yes they do make them for the Rancher). The install should be like the muffler install on a car. Just unbolt the old and bolt on the new.
I just install the same exhaust on my Rancher. Easy job, One clamp, and two or three hangers. Take the back tire off for easy access. I went with the K&N High Flow Air Filter and the Dynojet Jet Kit. The Jet numbers are not equivalent. But the 130 dynojet main and needle worked great for me. I bought the kit from Highlifter used the largest jet in the kit and put the needle on the 3rd notch.
Very impressed with the new found lowend power. I can easily understand why Honda didn't ship the Rancher this way. All that power and acceleration wound make the Honda Lawyers very nervous. My test ride out of the garage I hammered the throttle in 2nd gear and lifted the front end off the ground without any effort on my part at all.
After riding a couple days I reduced the disc in the exhaust from 12 to 7. Reduced the noise level to an acceptable level but didn't seem to effect the power. I have a good relationship with my neighbors and wanted to keep it that way.
Best of luck with you mods.
