300ex Lighting...
Old Jul 18, 2000 | 12:07 PM
Exer_95's Avatar
Ok.. I have the stock healight sysytem on my 300ex. It is bent down, and will not stay up.. I know I can get a new bracket. But I was thinking about getting one of those headlight kits from Wal-mart (two smaller lights, similar to the 400ex size) and and mounting them up instead of that stock thing. I would custom make a head light bracket system (similar to the Warrior) to mount it up. Also, I would mount the nuetral and reverse lights up there to.
Know to my question.. Will there be any need to change anything else on the quad. Can the electrical System handle that change or do I need to upgrade something !! Please give me some advice on this !!!
Jason
Old Jul 18, 2000 | 01:33 PM
THEXOTIC1's Avatar
Find out what your stock stator output voltage is then take half of that. This will be you running wattage. Or contact Ricky Stator for the answer. You can also get your stator rewound so it can handle more wattage. Oh i forgot you said 300ex my fault you have a battery. You should be able to run a pair of 35 watt driving lights. I think the light on high is 60-65 watts. But take it apart and check out the wattage of the bulb.
Old Jul 19, 2000 | 02:52 AM
4trax300ex's Avatar
my old headlight shorted out the other night and i bought two smaller lights they come in singles for 20 dollars i have racing plastic so i mounted them right where the screws go to hold the plastic it took 20 min to wire them in they are a little brighter and look great compared to my also bent down cracked headlight braket
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
