air/fuel screw settings
Old Apr 2, 2004 | 03:49 PM
yamahawarriormods's Avatar
Default air/fuel screw settings
can anyone tell how many turns out the air/fuel screw has to be on a ds650
Old Apr 2, 2004 | 09:19 PM
JMAC650's Avatar
around 2 1/2 to 3 1/2 turns.
Old Apr 2, 2004 | 09:30 PM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
There are SO many variables involved that its hard to exactly tell you from one machine to another.
There is a procedure that many people use that will help simplify this question for you.
At an idle....
Turn the screw IN slowly, until you hear the engine begin to change RPM (bog).....
Now, begin turning the screw OUT slowly, while counting the number of turns, until you hear it bog again....
Now divide the number of turns in half, and return the screw to that point.
Should get you really close.
p.s. If you are less than 1 turn out, or more than 3 1/2 turns out....a different pilot jet may be in order.
slowgsxr97
Mar 18, 2022 03:40 AM
fordfaithful21
Dec 7, 2015 05:52 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
cdoren
Aug 16, 2015 11:22 PM
