P 650 submarine help
Old Apr 2, 2004 | 10:06 PM
SHOEFITS's Avatar
Default P 650 submarine help
when my p 650 had 80 miles on it i had the misfortune of sinking my quad. i tried everything to get it restarted .it wouldnt start acted like it lost compression. i tore it down and the rings were froze on pistons. i reringed it now it runs great now.today a guy brought his 02 p 650 in my shop today he sunk his to. i tore it down and it has the same problem as mine . rings stuck to piston. has any body elese had this happen????
Old Apr 2, 2004 | 10:32 PM
Customfabandweld's Avatar
What stuck the rings to the piston? Was it silt wedged between the ring and the ring land?
Old Apr 2, 2004 | 10:39 PM
meangreenmudmachine's Avatar
yes, I had the same misfortune as you and your bud. I took it to my local Kawi shop and was told I would have to have a rebuilt engine. I decided to get a second opinion because this shop is a little shady anyway. I went to a local small engine repair shop, where I knew the guys personally, they started by simple things like changing oil multiple times, and simply cleaning everything very well. They ended up finding out the reason it wouldn't turn over was that there was water in the piston chambers ( or whatever you call them I'm not a mechanic by no means).
So basically the cylinders were full of water and the engine couldn't force that water out by just simply turning over by trying to crank up. He somehow drained that water and after a little more TLC. I'm here today riding the same machine for only $160 dollars instead of Kawi's $1800.
Not saying this is an answer for you but hope it helps.
Old Apr 2, 2004 | 10:49 PM
SHOEFITS's Avatar
the two top rings were stuck in the ring grove. the bottom scraper was free. it didnt hurt the cyl walls. i used a small pick to remove stuck rings. bubble honed the cyl . and installed new std. rings. i run klotz synthetic in my bike. i called kawasaki they said it shouldnt have any affect. now i am more careful about running in deep water!!!!!! rick
Old Apr 3, 2004 | 03:52 AM
Here in California, we don't have standing water thats deep enough to sink a quad, unless it's in a lake![img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 3, 2004 | 04:15 AM
SHOEFITS's Avatar
mine busted through the ice on my pond. u do know what ice is in cali?
Old Apr 3, 2004 | 01:08 PM
I have a vague idea, it's what you put in your drink, right?[img]i/expressions/face-icon-small-wink.gif[/img]
Angel of Death
Oct 18, 2009 09:49 PM
RticKwad
May 4, 2008 02:54 PM
Zoltron
Aug 16, 2003 08:59 PM
Zoltron
Jun 29, 2003 04:36 PM
Taylormade
Jan 3, 2003 10:03 PM
