i need to know how to fix before tommrow
Old Apr 3, 2004 | 05:42 PM
BT250racer's Avatar
Default i need your guys help ASAP!!!
i went to change the main jet today and like the carb was leaking gas where the float bowl connects. how the he!! does the float bowl stay on the carb!??
Old Apr 3, 2004 | 05:57 PM
BT250racer's Avatar
( the bowl is complete off and i looked and looked but cant find how it did stay on)
Old Apr 3, 2004 | 07:50 PM
vig's Avatar
vig
Did you remove the whole bottom on the carb? If you did there is a little pin that holds the float assembly on ,it will slide out very easy and is easy to lose. good luck
Old Apr 3, 2004 | 08:27 PM
BT250racer's Avatar
well this is the first time i ever toke a carb apart, i thought u had to take off the float bowl to get to the main jet but i just didnt get my facts straight yes the hole bottom part of the carb came off and is still off. i did take out 4 screws that went throught the bowl but the bowl didnt have any threads in for them. so im really confused how to put the 2 pieces back together.... where is this pin located and etc????
Old Apr 3, 2004 | 09:15 PM
quadwrench's Avatar
Default i need to know how to fix before tommrow
Try this diagram : Typical Polaris 2 stroke carb
maybe it will give you some insite as to where you are going wrong
Old Apr 3, 2004 | 09:47 PM
BT250racer's Avatar
thanks but how does #20 connect to number #28
Old Apr 3, 2004 | 09:48 PM
MrZeeedler's Avatar
with the nut on the bottom of the bowl
Old Apr 3, 2004 | 09:52 PM
trailrider500's Avatar
The nut on the bottom on the bowl is just for access to the main jet...
BT250racer, did you get my PM?
Old Apr 3, 2004 | 10:00 PM
BT250racer's Avatar
yea i did and the 4 screws does screw into the top of the carb but there isnt any threads on the bowl.
Old Apr 3, 2004 | 10:02 PM
The screws go in from the bowl side of the carb not from the top, the bowl doesn't have threads only the carb body has threads...
