It has been a year since I got my bike what should I do?
Old Apr 4, 2004 | 06:59 PM
markbanger's Avatar
Default It has been a year since I got my bike what should I do?
It has been a year since I got my bike what should I do? I know I have to change my oil but what else do I have to do. I have a 03 trail boss.
Old Apr 4, 2004 | 08:53 PM
markbanger's Avatar
Anyone?
Old Apr 4, 2004 | 09:18 PM
watzupdog's Avatar
[img]i/expressions/face-icon-small-frown.gif[/img]
Old Apr 5, 2004 | 01:03 AM
BigBadScrambler's Avatar
oil, trans fluid, any chain or diffs that need to be cleaned/changed (dont know what the boss has) valve adjustment, fuel filter, clean the clutches, check the radiator fluid, grease her up. You may also want to pick up a service manual. It will have all this info in it
Old Apr 5, 2004 | 07:26 AM
markbanger's Avatar
How do you change your trans oil and fuel filter i've never done this before.
Old Apr 5, 2004 | 01:36 PM
scootergptx's Avatar
Supersock
Hired Gun!
I'll check the manual tonight and get back with you if no one else has. Shouldn't be a whole lot of differnece between the 325 and 330 as for as procedure goes.
Old Apr 5, 2004 | 06:27 PM
Scootergptx should be able to tell you where your trans fluid drain plug is. Im not sure on the boss, but mine it near the crankcase drain plug. The fuel filter should be located on the gas line that goes from the gas tank to the fuel pump. You can pick up any fuel filter for a 1/4" fuel line at just about any autoparts store. You can even buy a reuseable one if you want.
Old Apr 5, 2004 | 07:30 PM
markbanger's Avatar
Is there a filter or a seal for the trans oil that I should have to replace to or do I just drain it and fill it back up.
Old Apr 5, 2004 | 07:39 PM
Just drain and fill. There MIGHT be a nylon washer on the drain plug, Im not possitive on that.
Old Apr 5, 2004 | 08:55 PM
markbanger's Avatar
Thanks just got back form buying 2 quarts of oil and a filter. I also just bought a fuel filter tras oil and brake pads. again thanks for the help guys.
