Scrambler 4x4 tire sizes
Old Apr 4, 2004 | 10:51 PM
Syklenut's Avatar
Default Scrambler 4x4 tire sizes
Do these have a matched size front and back to accomodate the gearing in the 4 wheel drive??
Like a Truck for instance you can't run a smaller tire in front and bigger in back. (well you can but you better not put it in 4 wheel!!!) ha ha any input would be appreciated thanks
Old Apr 4, 2004 | 10:53 PM
BT250racer's Avatar
when u change the tire size make sure the front tire is one inch taller then the back tire
Old Apr 4, 2004 | 10:59 PM
Syklenut's Avatar
So like a 24x8x12 on front and a 23x11x10 on back?? correct??
DGScrambler400's Avatar
The stock tires are 22x11x10 (rear) and 23x7x10 (front). ALWAYS keep the front tires one inch larger, or else 4x4 will not engage correctly!!
Old Apr 4, 2004 | 11:06 PM
Syklenut's Avatar
Okay lets get this straight.. first #is height of tire? second # width? and third is rim size?? I am just making sure so i don't screw up
Old Apr 4, 2004 | 11:09 PM
thats right... Height x Width x Rim size
Old Apr 4, 2004 | 11:13 PM
Syklenut's Avatar
gotcha!!! thanks a bunch
Old Apr 4, 2004 | 11:44 PM
Whitedog's Avatar
You could go with a 25 on the back, But you would have to change your sprokets to gear it down. There is a formula for figuring tire size and gear ratio. to get it back where it belongs, but I dont know what it is. Ive stated on here before, I run a 24 on the back and a 23 on the front and the 4wd works fine. As long as those back tires are spinning faster than the front, in the mud, then the front is going to engage.
Old Apr 5, 2004 | 12:27 AM
Syklenut's Avatar
So does anybody out there know what the formula is?? I am actually running stock right now but i am thinking about dropping a size or two to mabey pick up a little more bottom end. I am just wondering what the downside is.(you don't get somthing for nothing) or would it be better to change it with sprockets?? input input I want input thanks guys !!!!
Old Apr 5, 2004 | 12:41 AM
Whitedog's Avatar
Maybe try a new post asking about the formula. I got a dirt wheels mag somewhere, with it in an article. I thot of calling National tire and wheel. They mite know it. Or maybe an Email 2 Offroad magazine.
