Exhaust Question
Old Apr 5, 2004 | 10:19 PM
SixStrings's Avatar
Default Exhaust Question
Got an 85 250es. Finally got a nice awesome quality OEM exhaust to replace the 10 time repaired old rusted one. It doesn't quite line up though...Guy said it was off an 86...#'s match...anyway, I've tried a few times installing it and every time I get a leak at the connection to the header pipe...How much of a leak if any is acceptable here? Think I gotta grind an 1/8" of the female end to get'er to go but before I take a nice OEM part to the grinder, figured I'd ask the experts. Also, I seem to have better performance now...but I just checked the plug and it looks carbonned up...is it normal to adjust mixture on carb when replacing exhaust?
Thanks
Old Apr 6, 2004 | 03:20 AM
ThrashAndCrash's Avatar
Did you use a new gasket between the muffler and head pipe?.......if so maybe you can notch the mounting holes a little to allow the muffler to move around to the propper placement. And if you replace a stock muffler with a stock muffler there should be no reason to adjust your mixture unless your last muffler was just a hollow piece of crap, then you might be running a little rich due to the new backpressure.
Old Apr 7, 2004 | 11:16 AM
drummerguy84's Avatar
once again, Id get a 4 stroke...lol...I got a straight pipe on mine [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 7, 2004 | 12:41 PM
Drummerguy84.......What the hell are you talking about?????????????[img]i/expressions/face-icon-small-confused.gif[/img] A 250ES is a 4 stroke.
Old Apr 7, 2004 | 12:50 PM
oops...my bad..I'm tired!...lol...
Old Apr 7, 2004 | 12:51 PM
well then a little leak wont hurt..my pipe leaks ....still performs...
Old Apr 7, 2004 | 01:02 PM
[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 7, 2004 | 01:10 PM
someone told me 4 strokes need back pressure too..is that true?..if it is..then y do funny cars...dragsters..and monster trucks have exaust shorter then my arm span?
Old Apr 7, 2004 | 01:20 PM
odysseyjunk's Avatar
drummerguy, backpressure in a 4 stroke helps torque, idle, and throttle response. in dragsters, they are meant to run wide open throttle and only for short periods of time. running with no exhaust causes the exhaust valve to heat up, and this will lead to detonation, but its ok for short times. also, i think larger, multi cylinder engines are less prone to this type of detonation. im no expert, but id be real interested in hearing from someone with more experience, knowledge on this...always learning......
Old Apr 7, 2004 | 01:24 PM
true...but I mean...even mt dads harly..it has straight pipes..lol...my bros mustang..he broke in the engine w/ just 1 foot of pipes!...lol...I know 2 strokes need it...but I dont think it makes a WHOLE lot of diffrience for a 4 stroke...but Im sure its noticeable..otherwise no one would be doing it..
Cole Hadden
Jun 15, 2025 09:05 AM
Shainasmash
May 8, 2017 06:38 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
HondaR24
Jul 21, 2015 12:12 PM
cSchwartz
Jul 12, 2015 07:42 PM
