ATC 200 Idol Problem
Old Apr 6, 2004 | 11:53 PM
PlatinumDogg's Avatar
Default ATC 200 Idol Problem
Hey everybody, new to this forum. I have an 1985 or 1984 trike. Originally it was a chain driven 1985 200m and then i had swiitched all body parts over to another frame with a shaft drive 200cc engine.. So im not sure on what year it is.. i dont know if you need to know the year or not..but anyways when its cold it will idol fine. When its hot after a fair bit of a ride, when i come to a stop, most of the time it will quit out. It starts back up very easy and i know the idol is up but i was wondering what the problem might be? Any help would be appreciated.
Old Apr 7, 2004 | 01:15 AM
IonSoul's Avatar
It's quite obviously a carb problem. I would take the carb apart and perhaps rejet it.
Old Apr 7, 2004 | 02:38 PM
ThrashAndCrash's Avatar
if you end up doing a carb rebuild kit...check out this post....it may help you find what year engine you have so you can find the correct kit...POST
Old Apr 7, 2004 | 02:39 PM
AND welcome!!!!!
Old Apr 7, 2004 | 06:07 PM
thanks alot buddy, turns out its a 84'. I was wondering how much a carb kit might run for?
Old Apr 8, 2004 | 03:16 AM
$20 at hyperparts Here
Old Apr 8, 2004 | 03:28 AM
rob0781's Avatar
The idle problem ,might be your valves outta adjustment.
Old Apr 8, 2004 | 12:24 PM
good point, plus you may want to adjust your timing chain as well.
Old Apr 9, 2004 | 01:09 AM
If i was to adjust the timiing chain, what would i go about doing to it? like advance it or retard it type thing?
Old Apr 9, 2004 | 01:44 AM
No....all you do when you adjust it is you put mor tention on it to take up some of the slop in the timing chain
