ATC 200 Idol Problem
Old Apr 9, 2004 | 02:13 AM
PlatinumDogg's Avatar
Default ATC 200 Idol Problem
alright..i will giver tomorrow and update ya
Old Apr 9, 2004 | 08:27 PM
dzzy's Avatar
Sounds like your needle jet\jet needle is worn. Use to replace them all the time on 185\200 ATC's. The hole in the needle jet gets too big from the needle sliding up and down in it and on these older machines the parts were brass so it happened easily. The symptoms were as you described. Other symptoms were plug fouling, inconsistent idling, and general rich running. After replacing the parts, it makes them a bit cold blooded, the choke becomes a necessary item, but they run excellent after warming up. If you order an aftermarket "carb kit" you probably won't get the parts you need. They are available from Honda as a kit called the needle jet set. Includes the two previous mentioned parts, the needle clip, and the retainer that holds the needle in the slide.
Old Apr 10, 2004 | 01:13 AM
Hey, yeah, the running rich and inconsistant idoling is all happening..i probbaly look for a kit this week or next week..right now i have the airbox lid off to keep it a little leaner[img]i/expressions/face-icon-small-smile.gif[/img]sounds cool lol, sorta like my buddies blaster[img]i/expressions/face-icon-small-confused.gif[/img] thanks for the help
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
