fuel filter
Old Apr 8, 2004 | 01:31 PM
markbanger's Avatar
Default fuel filter
Where is the fuel filter on my 03 trail boss I can't find it.
Old Apr 8, 2004 | 03:36 PM
BigBadScrambler's Avatar
Default fuel filter
#16 on this diaghram. It is located on the gas line coming off your tank
Old Apr 8, 2004 | 04:22 PM
markbanger's Avatar
Default fuel filter
There are 2 lines coming off the tank and they both go to the gas On, Off switch thing. I think it is in the middle line coming off the On off thing. But it doesn't look big enough. Is it in the end or the middle of the line?
Old Apr 8, 2004 | 04:29 PM
DaveMaxx's Avatar
Default fuel filter
Yes, it is in the line coming from your On, Off switch thing to the fuel pump. Midway or so and it is as big around as my ring finger.
Old Apr 8, 2004 | 09:50 PM
markbanger's Avatar
Default fuel filter
How do you get the old one out and the new one in?
Old Apr 8, 2004 | 10:21 PM
predatordude's Avatar
Default fuel filter
If you have the side panels off and still can't reach it, you may have to loosen up the fuel tank mount bolts or air box to reach in. Just remove the clamps on each side of the filter and put new one in. it will leak a little gas, so have a rag
Old Apr 8, 2004 | 10:29 PM
markbanger's Avatar
Default fuel filter
Ya I have the front and side plastic off the fuel tank is off to. I was wondering how to get the fuel filter out of the hose.
Old Apr 8, 2004 | 11:15 PM
Default fuel filter
Just pull it off. It is held on with clamps. If it is giving you trouble, put a little heat on the hose and it will come off easier (DONT USE A FLAME!!!)
Old Apr 9, 2004 | 10:44 AM
markbanger's Avatar
Default fuel filter
So if the fuel filter is clamped on it must be at the begining or end of the hose not the middle? Or is it in the middle?
Old Apr 9, 2004 | 02:28 PM
Default fuel filter
Mine is more toward the end, right before it gets to the pump. You MAY have to take the tank off (if you havent already) to access it
