2 stroke questions . . .
Old Apr 8, 2004 | 08:28 PM
3WF's Avatar
3WF
Default 2 stroke questions . . .
Hey. I know this is a really stupid question but do 2 strokes mx bikes/quads need reeds? Manufacturs just came up with reeds to make the powerband less brutal right? Im just wondering if they are really needed or not, if you dont run reeds can it mess up the bike/quad?
Old Apr 8, 2004 | 09:27 PM
Bradracer18's Avatar
yeah they need reeds
Old Apr 8, 2004 | 09:42 PM
killerKXF's Avatar
I think it would stay flooded
Old Apr 8, 2004 | 10:58 PM
ftwflh's Avatar
ALL 2strokes dont need reeds.Polaris 250-300s dont use them.But if the engine is desinged for them they need to be there.
Old Jun 1, 2004 | 07:31 PM
HYDE's Avatar
2-stroke refers to the amount of times the piston needs to move up and down to complete 1 compression. 2 sroke engines need reeds because when the engine makes each compression the reeds open to let in a fuel/air mixture and then they close when the whole combustion process is taking place. if ur still confused go 2 macdizzy.com this site is all about 2 strokes
Old Jun 1, 2004 | 08:50 PM
bansheeesmoker's Avatar
yep and during the exhuast stroke the pressure would send fuel backwards through the carb, thats why they have a tapper the reeds will only open one way with pressure aplied to both sides.
Old Jun 1, 2004 | 09:45 PM
Skidoomxz's Avatar
Piston port, Case Reed, Cylinder reed, rotary vavle are all forms of intake for a two stroke engine. Piston port uses the piston as a vavle to let the air fuel mixture in threw holes in the cylinder wall. There is a kit to convert pport to a reed intake, better fuel dissipation. This is old technology. Rotary valves were used on a lot of skidoo snowmobiles, it uses a valve to open and close the intake port. So NO two strokes do not need reeds unless they have a reed designed intake.
Old Jun 19, 2004 | 01:46 AM
hondaguy13's Avatar
if u take the reeds out of a bike it probably wouldn't run but i wouldn't try to run it w/o reeds
Old Jun 19, 2004 | 05:00 PM
mahnster's Avatar
If the engine is designed to have reeds you need to have them on there.
Old Jun 20, 2004 | 12:41 AM
Bubba297's Avatar
If you totally remove them it would not start. The reeds are designed to hold in the primary compression until the transfer ports open to allow the fuel to be "pushed into the cylinder". The port timing and piston design is different on non-reed motors. Reed type motors generally have better throttle response and better bottom end power (stock vs stock). By the way 3WF, the only stupid questions are the ones you never ask. Asking is part of learning. Don think the questions you ask are silly. You might get some dummies that make fun of it, but most are here to help and share info.Bubba
tastyatv
May 28, 2023 11:11 PM
kelleycully
Sep 15, 2016 02:57 AM
Big bousse
Sep 26, 2015 10:42 AM
Anomers
Aug 16, 2015 11:06 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
