toomeys and jetted blaster
Old Apr 9, 2004 | 11:16 PM
blasterrider04's Avatar
Default toomeys and jetted blaster
will this improve my blaster from stock form because yesterdya i got my stock blater clocked at 63 pushin 64 and was wandering wat the toomey kit will do
Old Apr 9, 2004 | 11:21 PM
RedEX's Avatar
won't add top end (at least not much), but it'll help you get their faster.
Old Apr 10, 2004 | 07:58 PM
Criminalpoet's Avatar
Pipe doesnt really have much to do with your top speed mph, if you want to achieve faster top speeds then you need to play with your gearing and rear tire size.. However, you cant really pull taller gearing without more horse power or you will be stressing the hell out of your motor... You need some good port work and head work and then you can change your gearing to like a 14 up front and 38 in the rear.
Everything you could want for your motor can be found at www.hollywooddirtproductions.com , and there is also a wealth of Blaster information on Hollywood Dirts message board as well so go and check it out... Nothing but Blaster gurus over there...
ReconBayou
Oct 31, 2022 05:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
nastyblaster100
Sep 13, 2015 01:19 PM
