Baja Lights ?
Old Apr 11, 2004 | 03:34 PM
BillDS650's Avatar
Default Baja Lights ?
Any body get the Baja light kit to work with the Carbon fiber radiator shrouds ?
Old Apr 11, 2004 | 04:09 PM
Sandaholic's Avatar
I have aluminum shrouds with my baja lights. The top two mounting spots are mounted directly to the baja lights aluminum cage. It works pretty good. If I were to do it over, I would probably ditch the baja lights and go with some trail tech HID lights. The Baja lights are a pain to adjust and even more of a hassle to change the bulb.
Old Apr 11, 2004 | 05:09 PM
BillDS650's Avatar
I am going with the Trailtech MR16 HID with the Ballasts on the Baja light bracket back side.
Old Apr 11, 2004 | 08:27 PM
BajaIowa's Avatar
I have the aluminum shrouds and all I did was take the guards off the lights and just have the mounting brackets. Looks good, and I can just bolt the cages back on if I need to.
Justin
Old Apr 12, 2004 | 12:21 AM
SANDMAN430's Avatar
i also mounted them with the aluminum shrouds.
Old Apr 12, 2004 | 02:40 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Check out my pics. I mounted a cheap set of light to my top shock mount bolt. I did also drill and install a small set screw to the light would not turn with shock travel. It is not the most expensive set up but it make a hugh difference.
Old Apr 12, 2004 | 03:13 AM
lilnotts's Avatar
mrds650, i'm pretty sure i have the exact same lights as you, i bought them at autozone for like $30, made by a company called pilot, they have soome pretty cool ones where you push a button and the outter ring lights up, but they were like $50-60
Old Apr 12, 2004 | 11:40 AM
fourlix's Avatar
I have the carbon fiber shrouds on my Baja X. See pic in my photo page.....I just bolted the carbon fiber shrouds to the aluminum light cages....This isn't what you are talking about it though is it?
akguy31
Aug 31, 2019 04:34 AM
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
Steeldon
Sep 9, 2015 09:38 AM
