another red light sensor question
Old Apr 11, 2004 | 07:57 PM
caandian's Avatar
Default another red light sensor question
first time i have ever washed my ds that the red light came on was today, just wondering what sensor is wet and will it dry out or is it toast?
Old Apr 11, 2004 | 09:37 PM
JMAC650's Avatar
It is the oil pressure sensor. It is located under the carb. It threads into the block and it has a single wire going to it. They are known for going out all the time. Most of the time you have to replace them. I keep 3 or 4 with me at all times in the garage. They make a boot for it to help keep out water but it doesn't work very well. I just wrap it with some plastic wrap and electrical tape before I wash it. The easiest way to check it is to start you ds and unplug the wire. If the light goes out it's you sensor.
Old Apr 11, 2004 | 09:59 PM
caandian's Avatar
i just repalced that one last fall that was the first time , no chance it will dry out?
Old Apr 12, 2004 | 12:49 AM
JMAC650's Avatar
Not sure. But it is good to have extra ones.
Old Apr 12, 2004 | 08:49 AM
TheOz's Avatar
Home much do these sensors cost and where can you order via the internet? Oh, if someone has a part number that would be cool too.
Old Apr 12, 2004 | 01:47 PM
Indianbullet's Avatar
any one just can the sensor and run a manual oil pressure guage??? i think im going to do that ...
Old Apr 12, 2004 | 02:19 PM
JMAC650's Avatar
They are like $12 at the dealer. Not sure where online you can get them.
Old Apr 12, 2004 | 03:03 PM
TexasPsycho's Avatar
i did away with mine and bought one of those triple gauge sets with the mini oil press, water temp amd volt gauges. i just used the oil and water gauge and mounted them on the panel where the tach usually goes. be sure and run the plastic tubing away from anything hot though so it doesn't get a hole rubbed or burned in it. i just ran 1/8" ss tubing. you might want to run the small plastic tubing through some vacume hose to protect it. you should be able to pick up a mini oil pressure gauge for $15 or so. the triple pack cost me $36.
bzdok1234
30
Feb 23, 2016 01:55 PM
DeFox500
Jul 26, 2015 06:32 PM
ltrmc02
Jul 22, 2015 04:50 AM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
