do it yourself speedometer
Old Jul 21, 2000 | 12:01 AM
pyromaniac442's Avatar
Can anyone help me out on putting a bike speedo on my Honda Recon? Has anyone done this before?
Old Jul 21, 2000 | 12:11 AM
azelmo's Avatar
Iam running a trek bike speedo on my polaris sport 400...just mount it on your bars,epoxie glue a magnet on your rim and make some type of mount for the sensor(I just zip tied it on the brake caliper) and set the speedo acording to the instructions works good
CHECK OUT MY HIGH PERFORMANCE POLARIS PAGE
SEND IN YOUR PICS AND SPECS
http://msnhomepages.talkcity.com/RightWay/hiperfpolaris
99 sport 400
hpd pipe
hpd muffler
hpd porting
hpd billet head
hpd girdle kit
39mm kehin pwk carb
renthal cr low bend bars
wiseco piston
hpd aggresive clutch kit
v-force reeds
k&n filter
2000 scrambler 400 2x4
prm alum. a-arm gaurds
dg alum. bumper
k&n filter
Old Jul 21, 2000 | 12:12 AM
Hey,is it pretty easy to install?
Old Jul 21, 2000 | 12:14 AM
Is it hard to adjust it to the wheel size and do you have to adjust it to the tire or rim size?
Old Jul 21, 2000 | 12:18 AM
azelmo's Avatar
you adjust by marking the tire..then rolling it around back to the mark.then you measure the distence it travled in mm then enter that # in the speedo
99 sport 400
hpd pipe
hpd muffler
hpd porting
hpd billet head
hpd girdle kit
39mm kehin pwk carb
wiseco piston
v-force reeds
k&n filter
dg alum. bumper
k&n filter
Old Jul 21, 2000 | 12:23 AM
Rdkill724's Avatar
It is pretty easy to install it!!!!!!!!!!!!............
Old Jul 21, 2000 | 12:24 AM
hey,could you e-mail me or something and try ro explain that to me a little better and in more detail? My e-mail address is Lance3187@aol.com
Old Jul 21, 2000 | 01:04 AM
Rdkill724's Avatar
why??????
Old Jul 21, 2000 | 01:44 AM
Deej's Avatar
Do a search on the ATV Connection Tech page. There has been some discussion there on the topic.
I agree it is a simple thing to install and setup. Basically:
- install the speedo where you want it
- install the magnet on a rim or some other object that rotates one revolution for every one wheel revolution. ie. Mount it on the rim, an axle or ???
- mount the pickup in a location that allows the magnet to pass in close proximity to it at each revolution. The magnet flying by the pickup sends a pulse to the speedometer. The speedometer counts the pulses over time and uses the calibration number to determine the speed you are going.
- to calibrate mine I guessed at the calibration number required by choosing one of the preset numbers for a small bicycle wheel. It was not accurate, but in the right ball park. I then measured a mile with the car and tested the ATV speedo. I kept changing the ATV speedo calibration number until the speedo read a mile over the measured distance. A very easy job.
The End,
DJ
Old Jul 23, 2000 | 11:45 PM
Rdkill724's Avatar
Just install it like you would install it on a bicycle.
