how much $ to re-jet?
Old Apr 13, 2004 | 08:19 PM
dondiesel444's Avatar
Default how much $ to re-jet?
how much should it cost to get my carb re-jetted??
Old Apr 13, 2004 | 08:33 PM
ostrich's Avatar
I just put a new main in mine $3.00 if I remember correctly
Old Apr 13, 2004 | 10:21 PM
JMAC650's Avatar
I paid $2.75 for my jets.
Old Apr 14, 2004 | 07:26 AM
I don't know how to do it myself, I am wondering how much it will cost to get it done.
Old Apr 14, 2004 | 12:23 PM
JMAC650's Avatar
It is very easy to do. All you have to do is remove the 4 screws on the bottom of the carb bowl and the main jet is the center jet that hangs down the farthest with a collar around it. It will say 165 on it if it is stock. Just list your mods on here along with your elevation and i'm sure we can help you out with what jet size will work for you. Also you might want to go to your local hardware store and pickup some new screws for the carb bowl. Most people switch to stainless steel allen head screws. The sizes and amounts are (3) 4x10mm and (1) 4x12mm.
Old Apr 14, 2004 | 12:46 PM
Yardbird's Avatar
Like JMAC650 said it's really easy to do it yourself. Also if you're going to do it yourself alot of people recommend replacing the stock phillips screws for stainless allen head screws. It helps to make it that much easier the next time. But if you don't want to do it yourself then you'll have to call around and get the going rates on labor. It could vary from $40 to $100 bucks an hour depending on where you live. Here in San Diego it's usually around $60-$100 bucks an hour depending on where you go. I would think they wouldn't charge you more than a half hour of labor but sometimes there is a minimum of 1 hour labor charge no matter how quick they do it. Plus you gotta haul that big ole beast up there too boot!!!
Old Apr 14, 2004 | 05:52 PM
yamahawarriormods's Avatar
yeh dont by a jet kit i did this before and spent about 60$ before i reliezed how easy it was....[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 14, 2004 | 05:57 PM
question: do I have to remove the carb from the quad to change the jet? and where do I get the jets, will any dealer have them?
my mods are: K&N filter in the box (right now the lid is on, should I remove it??), Big Gun exhaust, right now it is the Race with new packing, but I want to add the quiet core to it. I live in upstate NY, I am guessing 1000 ft above sea level? I'm not really sure...
I think I am gonna try to to this, so can anyone recomend the correct jet to use?
Old Apr 14, 2004 | 07:06 PM
rldbobcat's Avatar
Where do all of you guys get your jets from?? I'm looking for a 175 ish main.
Old Apr 14, 2004 | 07:22 PM
JMAC650's Avatar
At sea level to 1000ft I would use a 172.5 mikuni main jet with lid on. Leave the needle in the stock position. Cut 4 coils off the slide spring. Air mixture screw 3 1/2 turns out and you should be pretty close to dead on.
To do the slide spring there are 2 screws on top of the carb. Take them off and remove the cap, cut 4 coils and put it back together. Be careful the rubber diaphram is back in its groove. This will let the stock carb rev up much quicker!
The jets you want are mikuni small round jets.
JohnnySplat
Aug 6, 2015 12:07 PM
SMW
May 18, 2001 04:40 PM
ssimons
May 20, 2000 10:08 AM
tomuchfun
Mar 16, 2000 06:20 PM
