Anyone have a pro design kill switch?
hey its very easy! connect it to the black and yellow wire comin from the coil......the place the plug wire goes if you didn't know......you connect the long one to that and just ground the other one. its real sipple if you have mor ?'s just ask. later
If you go to a rdio shack dealer they have a black tap in that is about 3/4 inches long. The black part will just press over the black/yellow wire on your quad. Then take the long one and crimp one of the supplied blue plugs with it. This will enable you to take the kill switch off without damaging your wiring if you need to. I just attached te ground to the bolt on top of the shock mount using a closed end connector.Next time I go by radio shack I will get the part #.
fordfaithful21
Dec 7, 2015 05:52 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
