Blaster steering stem?
Old Apr 18, 2004 | 02:21 PM
YAMAHARIDER4LIFE015's Avatar
Default Blaster steering stem?
When I replace my bent steering stem with a new one is there any bearings or other things that must be replaced?
Old Apr 18, 2004 | 02:25 PM
fasterblaster0102's Avatar
depends on if ur bushings are good or not
Old Apr 18, 2004 | 02:54 PM
the only thing you may have to replace is ur bushings if they are bad
Old Apr 18, 2004 | 02:59 PM
alright, thanks i'll have to check them
Old Apr 18, 2004 | 06:14 PM
Shav0's Avatar
there is only one bushing on the bottom of it.
It is probably still good. I bent mine and the I just bent it back, still works and alot cheaper.
Old Apr 18, 2004 | 07:16 PM
if i were you yamaharider4life015 i would replace your stem instead of doing things half assed like ol' shaveO no offence Shavo. also was you bushing damaged??
Old Apr 18, 2004 | 09:30 PM
any luck on them bushings
Old Apr 18, 2004 | 10:35 PM
Shav0's Avatar
Its not half a$$ is you do it right. I had a local machine shop press it and straightened it as good as new. its re-inforced inside so it won't be happening again. Plus its all sanded down and polished up so in my opinion its better then new.
Don't be bashing my **** without knoing the facts dude
Old Apr 19, 2004 | 12:00 AM
The bushings look alright, i would have taken my steering stem to a machine shop but i already bought a good used one, if you find a machine shop that does a good job it is probably the way to go, thats what i did with my axle
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Ahtatu
Sep 28, 2015 12:14 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
nastyblaster100
Sep 13, 2015 01:19 PM
