Proper Gearing For 2004 DS 650 Baja
Old Apr 18, 2004 | 02:57 PM
Romano's Avatar
Default Proper Gearing For 2004 DS 650 Baja
I am purchasing a new 2004 DS 650 baja and would appreciate some guidance on proper gearing. I will be riding primarily on the sand. I have been told to go with one tooth less on the counter sprocket. Does this sound about right?. I plan on running 22 inch hauler extremes on the rear and I weigh 240 pounds.
Thank you in advance
Old Apr 18, 2004 | 03:12 PM
BigDogAZ's Avatar
The 22 in tires change the gearing already. I would stay with that on a stock DS
Old Apr 18, 2004 | 03:27 PM
BillDS650's Avatar
If you want to climb big dunes 15/43, if you want to go fast on the flats stock 16/40 or 17/40, general all round 15/40. The 15/43 will require a new chain.
Old Apr 18, 2004 | 07:15 PM
Romano's Avatar
Thanks for your Advice. Do you how many teeth the stock sprockets have front and back?
Thanks
Old Apr 18, 2004 | 08:34 PM
dondiesel444's Avatar
stock is 16/40
Old Apr 18, 2004 | 10:00 PM
DCryder's Avatar
IMO 15/42 is perfect on a stock engine DS with 22" Haulers. Stock chain can also be used. I also don't think a stock engined DS will gain any top end speed on sand with 16/40 and especially 17/40, 5th gear would probably be useless.
COFatboy
May 2, 2020 12:06 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
velcro7279
Aug 24, 2015 01:15 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
