Sparks and raptor
Old Apr 20, 2004 | 02:45 PM
ripit's Avatar
Default Sparks and raptor
i am purchasing a sparks x-6 with a umi alum airbox and was curious if i should get the dynojet kit. also any experience what the jetting should be.
thanks.
Old Apr 20, 2004 | 02:57 PM
bird660's Avatar
i dont know anything about sparks system,but i heard if you dont jet with exauhst or slipon you will burn your $#it up. about jetting it should have a recomendation with the exauhst. i got all gytr. good luck
Old Apr 20, 2004 | 02:58 PM
bird660's Avatar
i also heard gytr has the best jet kit available for the raptor. and mine is great. no problems
Old Apr 20, 2004 | 04:30 PM
RaptorOwner's Avatar
Just call Scott at Sparks Racing 661-872-4343 and ask him what to jet it too. I dont mess with any screws and mine just with the pipe and airbox mod rips. Be sure to get the Dynojet kit because that is what they use.
Old Apr 20, 2004 | 04:51 PM
ripit's Avatar
thanks guys...i will go with the dynojet..i put that into a bored warrior with a dmc and custom airbox and they worked fine for me...the main reason for the ? is that i see ppl specify 2 jets for ex. 160/165 which i am gathering is for the 2 carbs...but why diff. sizes for each carb?
Old Apr 20, 2004 | 04:58 PM
Different size ports on the intake. If you look at the Raptor the left port is smaller than the right.
Old Apr 20, 2004 | 05:05 PM
ripit's Avatar
did not know that...thanks for the fyi...
Old Apr 20, 2004 | 10:31 PM
maddog56's Avatar
The left port only services 1 valve, while the right services 2. Thats why the jetting is higher on the right side carb.
Old Apr 20, 2004 | 11:12 PM
shackattack's Avatar
I learn something new here everyday.
Old Apr 24, 2004 | 03:25 AM
maddog56's Avatar
Let me make that clearer. The left carb primarily hits the single valve, and the right primarily the right 2. The chamber is all one area but the carbs have a better shot to the repspective locations.
