Wanted: Stock 2003 P650 Igniter
Old Apr 21, 2004 | 12:30 PM
PAPrairie650's Avatar
Default Wanted: Stock 2003 P650 Igniter
I did some testing after my rollover this weekend and I determined that I am not getting power to my fuel pump. According to the service manual, it states that no power to the fuel pump indicates a problem with the igniter. I have spark to my plugs, but no fuel to the carbs. So it looks like I will have to replace my ingiter. I wanted to get the Dyna CDI, but they said there will be no more available until the first week of June. I really don't want to wait that long to be running again. A new one from Ron Ayers is $280.00. OUCH!!! So if any of you that have replaced your stock ingniter with the new CDI want to sell your stock one, let me know. BTW, mine is a 2003 P650 A2 with igniter part # 21119-0004.
Old Apr 21, 2004 | 12:32 PM
cueball89's Avatar
I have my stock ignition from my 03 650.
Old Apr 21, 2004 | 12:33 PM
cueball89's Avatar
Roll over, i think there is some switich that cuts fuel from the quad.
Old Apr 21, 2004 | 02:00 PM
Yes, there is a switch that cut the fuel off when you rollover. It is the vehicle-down switch or invert switch whatever you want to call it. I checked that and it is working allright. I really don't know what else it could be according to the service manual. Is your stock ingiter part#21119-0004? I don't know if all '03's use the same ingiter or not. What do you need to have for it?
Thanks
Old Apr 21, 2004 | 02:10 PM
prairie633's Avatar
The Igniter gounds the fuel pump through the Black/Red Stripe wire. You may want to ground this wire manually and listen for the fuel pump before you spend some money?
Old Apr 21, 2004 | 02:17 PM
Thanks for the tip. I will try that tonight and see if it works. It should work if I bypass the igniter and ground it manually if the problem is indeed in the igniter.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
slowgsxr97
Mar 18, 2022 03:40 AM
bradco
Aug 21, 2015 08:11 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
