Wanted: Stock 2003 P650 Igniter
I did some testing after my rollover this weekend and I determined that I am not getting power to my fuel pump. According to the service manual, it states that no power to the fuel pump indicates a problem with the igniter. I have spark to my plugs, but no fuel to the carbs. So it looks like I will have to replace my ingiter. I wanted to get the Dyna CDI, but they said there will be no more available until the first week of June. I really don't want to wait that long to be running again. A new one from Ron Ayers is $280.00. OUCH!!! So if any of you that have replaced your stock ingniter with the new CDI want to sell your stock one, let me know. BTW, mine is a 2003 P650 A2 with igniter part # 21119-0004.
Yes, there is a switch that cut the fuel off when you rollover. It is the vehicle-down switch or invert switch whatever you want to call it. I checked that and it is working allright. I really don't know what else it could be according to the service manual. Is your stock ingiter part#21119-0004? I don't know if all '03's use the same ingiter or not. What do you need to have for it?
Thanks
Thanks
Thanks for the tip. I will try that tonight and see if it works. It should work if I bypass the igniter and ground it manually if the problem is indeed in the igniter.
bradco
Aug 21, 2015 08:11 PM
