2003 Raptor660 Backfire Issue
Old Apr 22, 2004 | 12:36 PM
Flaste's Avatar
Default 2003 Raptor660 Backfire Issue
Maybe someone can offer some suggestions as to what might be the problem. I just installed the full DMC Alien dual exhaust system, and jetted the carbs with a dynojet kit. It fires right up, idles nice, responds real nice to throttle.. but when i rev high and let off the throttle, i get a popping backfire.. pretty annoying! I havent really checked anything out yet. I followed the instructions in the kit, put a 146 jet in the left carb and a 148 in the right because I'm at about 1500ft above sea level. Screwed both the fuel mixture screws all the way in, then backed both out 3 turns. Put everything back on the quad, and it fired right up, idled well.. just got the backfire issue to contend with.
Any help would be appreciated!
Thanks
Old Apr 22, 2004 | 12:43 PM
HoundDog06's Avatar
You are probably a little lean. Check your plug.
~HoundDog
Old Apr 22, 2004 | 12:44 PM
FarmStud's Avatar
Welcome to the forums!
You sound lean on your idle mixture, turn the screw out a bit more
Old Apr 22, 2004 | 01:45 PM
caliraptor's Avatar
after 3 turns out on the pilots, I would suggest going with bigger pilot jets.
Old Apr 22, 2004 | 02:00 PM
Flaste's Avatar
Thanks for the welcome! I will try that out and see. Thanks
Old Apr 22, 2004 | 02:02 PM
Flaste's Avatar
Why's that?
Old Apr 22, 2004 | 03:26 PM
caliraptor's Avatar
your maxing out the pilots, so if you go with bigger ones, you will only turn them out 2 turns or so.
Old Apr 22, 2004 | 03:55 PM
Lomax's Avatar
I have A Full DMC Alien on my 04 Raptor. Try running 27.5 pilots air screws 3 turns out (left carb) 3 and 1/2 (right carb) and 155 160 mains with no airbox lid or one thats drilled out really good. thats a good performance enhancer, but the poping is just your pilot jets run 25's or 27.5's if it persists. (same size pilot in both carbs)
Old Apr 22, 2004 | 03:56 PM
Lomax's Avatar
I mean 150, 155. 155, 160 is with a k&n with no lid and 160, 165 is dual k&n with no airbox (thats what i got).
GregM
Mar 6, 2018 06:53 AM
velcro7279
Aug 24, 2015 01:15 PM
bpegram84
Jul 22, 2015 08:15 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
