2003 Raptor660 Backfire Issue
Old 04-22-2004, 12:36 PM
Flaste's Avatar
Default 2003 Raptor660 Backfire Issue
Maybe someone can offer some suggestions as to what might be the problem. I just installed the full DMC Alien dual exhaust system, and jetted the carbs with a dynojet kit. It fires right up, idles nice, responds real nice to throttle.. but when i rev high and let off the throttle, i get a popping backfire.. pretty annoying! I havent really checked anything out yet. I followed the instructions in the kit, put a 146 jet in the left carb and a 148 in the right because I'm at about 1500ft above sea level. Screwed both the fuel mixture screws all the way in, then backed both out 3 turns. Put everything back on the quad, and it fired right up, idled well.. just got the backfire issue to contend with.
Any help would be appreciated!
Thanks
Old 04-22-2004, 12:43 PM
HoundDog06's Avatar
You are probably a little lean. Check your plug.
~HoundDog
Old 04-22-2004, 12:44 PM
FarmStud's Avatar
Welcome to the forums!
You sound lean on your idle mixture, turn the screw out a bit more
Old 04-22-2004, 01:45 PM
caliraptor's Avatar
after 3 turns out on the pilots, I would suggest going with bigger pilot jets.
Old 04-22-2004, 02:00 PM
Flaste's Avatar
Thanks for the welcome! I will try that out and see. Thanks
Old 04-22-2004, 02:02 PM
Flaste's Avatar
Why's that?
Old 04-22-2004, 03:26 PM
caliraptor's Avatar
your maxing out the pilots, so if you go with bigger ones, you will only turn them out 2 turns or so.
Old 04-22-2004, 03:55 PM
Lomax's Avatar
I have A Full DMC Alien on my 04 Raptor. Try running 27.5 pilots air screws 3 turns out (left carb) 3 and 1/2 (right carb) and 155 160 mains with no airbox lid or one thats drilled out really good. thats a good performance enhancer, but the poping is just your pilot jets run 25's or 27.5's if it persists. (same size pilot in both carbs)
Old 04-22-2004, 03:56 PM
Lomax's Avatar
I mean 150, 155. 155, 160 is with a k&n with no lid and 160, 165 is dual k&n with no airbox (thats what i got).
GregM
03-06-2018 06:53 AM
velcro7279
08-24-2015 01:15 PM
bpegram84
07-22-2015 08:15 AM
MATT BOOTH
Technical and How-To Articles
07-20-2015 07:38 PM
MATT BOOTH
Utility ATVs
07-20-2015 05:55 PM
Quick Reply: 2003 Raptor660 Backfire Issue
