how to tighten my blazer's chain
First loosen the two bolts that hold the rear brake around the axle. Then loosen the two on the axle carrier. Then take a puch and place it in the small hole on the rear sproket carrier. Make sure the hole is on the top. Then push the quad forward i think tightens it. If not pull it back it will tighten it. Then leave it tight and tighten up the axle bolts first then the brake bolts after.
If you have a problem let me know. I just did mine last week. Very easy.
Then do what bisho12 said. If I weren't busy I'd mosey right over and show ya (I'm in Old Town)....
Hey, when i had to tighten my chain, i broke 2 puch pins, a screw driver, and a couple of nails. The easy way to do it if you start to break things is just losen the bolts, the ones talked about above, and then take a monkey wrench or a large pair of pliers and turn your back end that way. I dont know what was with my blazer, the guy at the shop had trouble doing it too. If your blazer is anything like mine, save the money and just use a big wrench or pliers.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
