Eiger exhaust spark arrest
Has anyone removed and cleaned their spark arrest screen. I tried to remove mine and it would not come out easily so I put the lock screw back in and gave up before screwed it up. Any advice??? I only have 100 miles on the machine but seen in the manual that you should clean it and just wanted to know how it comes apart.
I had the same problem. I just sprayed it a few times with WD40 then took a large pipe wrench and worked it back and forth until it slid out. It was pretty tight and I bent the outer ring up a little but hammered it back out on a vise. I removed the screen to prevent having to go back in there again.
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
