Wolverine diff fluid
Old Apr 23, 2004 | 03:18 PM
Remington911's Avatar
Default Wolverine diff fluid
I was sold some Bel-Ray 80W-90 GL5 fluid from the dealer. Will this work for both the front and back? The owner's manual calls for SAE80 in the rear but Bel-Ray doesn't make it. Are they the same thing?
Old Apr 23, 2004 | 07:27 PM
eja's Avatar
eja
By the manual it calls for GL4 but had a dealer tell me GL5 was alright for both.
Old Apr 24, 2004 | 11:42 AM
95wolv's Avatar
I would go with the GL5, it is rated for a limited-slip differential, which you have up front. You will also need to get some General Motors limited-slip additive, and put an ounce up front for the clutches in there, otherwise you will lose the grip of the front end some, and may notice some clicking or ratcheting noises from the posi clutch up front. I got some Amsoil gear lube, seems to hold up really good, and is rated for limited slip axles.
MaasaiMomma
Mar 25, 2021 11:24 AM
hueby
Nov 6, 2015 11:34 AM
John Reed
Sep 9, 2015 03:46 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
