blaster injector ?
Old Apr 23, 2004 | 06:49 PM
wanaply21's Avatar
Default blaster injector ?
can i put red line oil in my injector? will it hurt it?
Old Apr 23, 2004 | 08:26 PM
bootboss's Avatar
yes its good for it....before i disconnected mine i was runnin redline.
Old Apr 23, 2004 | 09:38 PM
Rider1169's Avatar
i used to run out board motor oil in my blaster, it was 1.33 for a 5quart bottle. thats about as bad of 2 stroke oil u can possible put in ur quad. it worked for me tho, so sure, that will be fine
Old Apr 23, 2004 | 09:39 PM
Rider1169's Avatar
incase any one is unsure of what out board is, its a boat, u probably all knew that, but making sure
Old Apr 24, 2004 | 08:53 AM
potentpete's Avatar
if your getting your cylinder ported you should really block that injector off, you'll just end up frying the piston and rings, those injectors can't keep up with the added fuel flow if you start modifying your blaster, I've seen many guys get porting done and keep using the injector and fry a top end in a few weeks, better to mix than trust that injector.
Old Apr 24, 2004 | 12:20 PM
wanaply21's Avatar
ohh dont worry thats the next thing on my list, i just spent all my money on the portwork and im flat broke right now, im gonna order it as soon as i get 30 bucks (prolly 2 weeks), i was told by the best when it comes down to blaster so im gonna do it, thx for the answers, ohh would it make me run richer or lean?
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
craacker
Sep 9, 2015 04:32 AM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
