carb problems?? maybe
Old Apr 23, 2004 | 10:27 PM
fox420girl's Avatar
Default carb problems?? maybe
It takes me forever to start. once started it will idel for a min then dies. 30 mins or more later when i get it started agian i feather the the throttle so it wont stall out agian. and i get a really deep sound and it stalls right away. so i thought it was the plugs. removed and replaced and did the spark test. that didnt work out so good. (its possiable i was just tired from kicking it so many times) spark test resluts = sparked once of 7 times. tryed the other side i lost count how many kicks it took to fire. so i disconnected tor's. now im getting no spark. tested coil (that was okay) tested. last effort without turining this into a large project i remove old gas replaced with correct mixture. and repeated tests stated above, recived simmilar results. also my choke was sticking a bit, i sprayd some wd-40 around it, choke seems to be working okay now.
has anyone had a simmilar problem? should i be taking off my carbs and cleaning them out? is part of my ignition system starting to fail? should i be checking my stator? i just want to go out and ride. some one help me its spring and my quads in the garage being un-fun.
Thank you in advance for any advise or help.
Old Apr 23, 2004 | 10:45 PM
sixsixT's Avatar
If it's been sitting for a while cleaning the carbs will probably do the trick.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
