Anyone use Total Seal Gapless Rings before?
Old Apr 27, 2004 | 02:32 PM
RaptorRacer1's Avatar
Default Anyone use Total Seal Gapless Rings before?
Looking for info on if anyone has experience using Gapless Rings with a Raptor piston. Did you get the rings with the piston or did you order the rings separate?
I am going to get a 11:1 100mm or 102mm Ross piston and I want to use a Gapless top ring. Can I do it?
RR1
Old Apr 27, 2004 | 06:08 PM
AlkyBurninX's Avatar
I didn't know they made any offerings for ATV's. I have used them in automotive applications though. I guess the thought behind them is good, but they don't seem to be worth the extra cost.
Old Apr 27, 2004 | 06:42 PM
Ward660R's Avatar
I know they are available from Total Seal for a 102mm. Other than that I don't know. Give them a call and have the specs of your rings handy. They should be able to help you out.
Old Apr 27, 2004 | 07:06 PM
I don't know if they can be used in an atv application or not, that is what I am trying to find out. Does anyone know? Should I call Total Seal? What specs on the piston do I need to know to ask them if they have rings that will fit?
Thanks!
RR1
Old Apr 27, 2004 | 07:09 PM
Thanks Ward.
I guess I was in the middle of typing my last post when you replied.
Do you know anyone who has used them? Were they happy with the results?
Thanks again.
RR1
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
Ahtatu
Sep 28, 2015 12:14 PM
