ES Shift, Angle sensor
Old Apr 27, 2004 | 11:18 PM
Loster666's Avatar
Default ES Shift, Angle sensor
The Angle Sensor of my Foreman have a Neutral Resistance of 4.9 KILO ohms .. In the manual they say that the
Neutral resistance should be between 4 and 6 Ohms ...
Is that an error on their side, because my angle sensor seem to work pretty well and I don't have any shifting
problems! . .
Thanks !
Old Apr 27, 2004 | 11:28 PM
Loster666's Avatar
Oh another question !!!
They say in the manual to put Esso N2 or N3 grease in the housing of the ES system (on gears etc) ..
I've put White grease there, do you think it is a bad idea or it doesn't change anything !? . . .
Old Apr 28, 2004 | 09:25 AM
dzzy's Avatar
If you don't have a shifting problem, it must be an error. It's always best to use recommended chemicals, but any grease is better than none at all. You should be fine with the white grease.
Old Apr 28, 2004 | 12:56 PM
Loster666's Avatar
Ok, well I suppose the angle sensor is just there to signal the CPU that the shifter is UP NEUTRAL or DOWN ...
So when I push the button It makes click than when it sense it's up it stop the shifter motor.. So it is working for sure ..
anyways . . .
And, on my white grease, it's written Number 2 Grease.. Is that equivalent to Esso Unirex N2 ?!..
Anyways, it should be better than how it looked when I opened the cover .. The grease was dry and mixed with sand ... Ishhhhhh . .
[img]i/expressions/face-icon-small-blush.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
