Raptor Choke Issues
The little plastic deal that screws into the carbs is broke. I really don't need a choke, what are my options? I can't think of how to block it off correctly. If I could find somthing that screwed in there I would just install the plunger and spring and be done with it.
You can dig out the rest of the nylon nut, cut the spring a little shorter, use a short bolt.. voila!!
But the peices to fix to stock are pretty cheap., comes with the plunger, spring, o-ring, nut. You dont need the whole cable.
GregM
Mar 6, 2018 06:53 AM
