Raptor Choke Issues
Old Apr 27, 2004 | 11:36 PM
LOWBOWTIE's Avatar
Default Raptor Choke Issues
The little plastic deal that screws into the carbs is broke. I really don't need a choke, what are my options? I can't think of how to block it off correctly. If I could find somthing that screwed in there I would just install the plunger and spring and be done with it.
Old Apr 27, 2004 | 11:41 PM
warrior007's Avatar
You can dig out the rest of the nylon nut, cut the spring a little shorter, use a short bolt.. voila!!
But the peices to fix to stock are pretty cheap., comes with the plunger, spring, o-ring, nut. You dont need the whole cable.
Old Apr 27, 2004 | 11:43 PM
LOWBOWTIE's Avatar
I'm trying to clean stuff up on the quad I might go the route of the bolt if I can find one that fits.
Old Apr 28, 2004 | 01:00 AM
LOWBOWTIE's Avatar
Has anyone used a bolt before? If so do you know the size and thread pitch? I just want to know so I don't have to pull off the carbs.
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
