GYT-R exhausts
I have the gyt-r for my rappy. It's a pretty decent exhaust for my rappy. It has good low to mid range power, but seems to lack in the upper end. I think they might be a bit too loud though. They are definitely much louder than stock. They don't sound bad though. But I believe there is a quiet insert available for them now. I'd say wait around for a little bit and see if any of the other companies come out with something new...
you should give it a little time
I have a 1st generation(2001) GYT-R for my rappy,,,,,it is loud,,,,and they dont even make parts for it anylonger (although pretty happy with it). (I bought it used on ebay for $140 in perfect shape)
Wait till the market is flooded with 350 pipes...then take your pick
The market is flooded with 350 pipes, they are called warriors. Most will be the same pipe for both models. Because the engine and the top end are the same, I see no reason why they should be significantly different. I dont believe the frame mounts have changed either. Only plastic issues should be noted.
so, a full warrior pipe fits a raptor 350,,,or just the slip on??
From the raptor 350 that I saw there shouldnt be any plastic clearance issues with the pipes. The mounting brackets look to be in the same location. I have not bolted a warrior pipe up to the mini raptor, so I cannot say for sure. The slip ons do appear to work. I have seen some posts from others who have warrior slip ons on their raptor 350.
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
